theoldwizard1
May 13, 2022Explorer II
You are overthinking this !!
If you install a DC-DC charger (highly recommended) immediately upstream for the batteries you will no longer need a battery separator. You should not need larger wire either. Your DC-DC charger will act as both a separator and limit the amount of power that can be drawn from the truck.
Add a gauge and shunt on the output side of the battery so you know how much charge it has.
44,071 PostsLatest Activity: Aug 23, 2026
