work2much
Jul 07, 2019Explorer
As mentioned above the fridge will have a helper fan. We upgraded ours to 2 fans that are much quieter. It can also be helpful to cover the lower vents in the top vent to force air over the coils better.
Here is a couple pictures of how our top vent was modified. I'm not sure if this was done by Dometic or Host.
Here is the stock fan which despite its diminutive size is quite noisy.
Here are the two fans that replaced it.
The fridge cooled fine with the stock fan but after replacing the single fan with two larger fans we found that we had to turn the temperature setting down on the fridge as we were starting to freeze things in the fridge.
