Looking for facts. :h
If I put a diamond plate aluminum aux tank in my PU bed and plumb it as follows:
No drain plug.
Tank is baffeled.
Use an electric pump to pull from a dip tube in the top of the tank.
Pump the fuel into a T in the main tank filler neck.
Install a Veton fuel shut off valve between the electric pump and the main. This valve will be closed automatically when not transferring.
The system has a roll over shut off valve in it.
Now will someone find a statute or DOT whatever that says that is not an approved or OK way of having a gas transfer/aux tank in the bed of a pick up?
Facts please.
