ughExplorerMay 02, 2015Larger gas tankIs it possible to add larger gas tank? I have 2001 F250 5.4V8 RWD Crew Cab. I got 8 MPG towing a 6,000 pounds camper. I had to stop for gas as the gauge was at 1/4, but I only covered 130 miles. I wan...Show More
trailerbikecampExplorerMay 03, 2015I have also sen dropping the tank. Pull the filler neck and cut a little off of it. It will effectively give you a larger tank. How much bigger will vary with how much you cut off. Make sure to leave yourself some leeway for expansion etc.
Related ContentLarger replacement fuel tanks for gas trucksLarger gray tank capacity trailersSmall gas tank beefLarger fresh water tank ?UPGRADE to a larger LP tank ?
