ugh
May 02, 2015Explorer
Larger gas tank
Is it possible to add larger gas tank? I have 2001 F250 5.4V8 RWD Crew Cab. I got 8 MPG towing a 6,000 pounds camper. I had to stop for gas as the gauge was at 1/4, but I only covered 130 miles. I wan...
WE3ZS wrote:
Your cheapest option would be to install an Excursion 44 gallon tank where your spare tire lives now. Get a tank from a gasser Excursion being parted out, fab up the 4 mounting points to your rear frame and make the needed plumbing mods for the fill neck and fuel lines.
Here is a write up from a Super Duty installation with pictures, for your application you can ignore all of the VO (Vegetable Oil) information.
https://dl.dropboxusercontent.com/u/38333511/F350%20tank.pdf
