Is it possible to add larger gas tank? I have 2001 F250 5.4V8 RWD Crew Cab. I got 8 MPG towing a 6,000 pounds camper. I had to stop for gas as the gauge was at 1/4, but I only covered 130 miles. I wan...
ATI also makes diamond plate aluminum tanks that are DOT certified for gas. They are roughly twice what the same size diesel only tank from Tractor Supply would cost. Best I can tell, you would have to pump from it to your stock truck tank.
