JCR-1ExplorerDec 25, 2017Latching relay ??Probably this question is better suited for the motor home channel however I will give it go here . I am trying to understand the purpose of a latching relay and then another solenoid (relay) to contr...Show More
BobboExplorer IIIDec 25, 2017There are two relays because they do two different things. The house battery is connected/disconnected from the house with a latching relay.The other relay connects the house battery to the chassis battery for charging, or boosting in case the starter battery is low and won't start the MH.
Related ContentRemote water pump switch - latching relay?relaysCompartment door latchDrawer latchesDoor latch
