DryCamper11's avatar
DryCamper11
Remote water pump switch - latching relay?
I want to install remote water pump switches that operate a latching relay to turn the pump on/off with a single press of a momentary contact switch. I'm tired of being out in the boonies and getting a piece of dirt in the pump or a leaky faucet and having the pump BRRRP every couple of hours at night while trying to sleep. I don't want to turn off the master pump switch while sleeping (which I could do now) since I don't want to walk to that switch each time I want to use water, so I need remote controls at 1) the kitchen, 2) in the bathroom and 3) in the outdoor water compartment.
I've got the momentary switches, 4 conductor wire and LEDs for pump ON/OFF display, but I need to buy a latching relay. The relay has to be zero power in both on and off states. A ratchet type relay is preferred. I have a double relay - two DPDT relays that mechanically interlock so when one fires, the other changes state, too, and vice-a-versa. Unfortunately, the relays are 120AC, so I'll have to rewind the coils. I'd prefer to buy one that's 12VDC and is a single ratchet type.
The pump is 5.5 amps, so I need about 10A DC capacity for the contacts. Does anyone know of an RV system like this sold commercially where I can just buy the relay part? I can probably find one at Grainger's, etc. but perhaps someone else has built this before and has a relay number. I've found some latching relays online, but can't seem to verify that they use zero power in both states (they may latch with power - it's hard to tell).
Any suggestions?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
