wnjj
Oct 01, 2013Explorer II
DryCamper11 wrote:Tom_M wrote:
Another type of latching relay uses a single coil and magnet. The first pulse pulls the contacts in and the magnet holds them in place. To release the contacts you pulse the coil with a reversed polarity pulse.
Yes, I've seen that type also. There are also some latching designs that have a small circuit inside to simulate ratchet type. They pulse on, pulse off, but need power all the time to hold on. One relay I found also has a mechanical button on top to mechanically operate the ratchet inside and switch it on/off. I looked up the Potter Brumfield relay I have in my scrap box just to see if there was a similar 12V version. (The one I considered rewinding). The replacement cost for that double relay was $150!
Are there any in that list at Digikey I posted that will work? Many are only $7 - $8.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
