carringb
Oct 21, 2013Explorer
GASA765 wrote:
Yes having repeated issues with CEL.
My '08 work truck had the the constant CEL issue. It had codes for MAP out of range. I knew the turbo was overboosting but the warranty would not cover cleaning. Bought the entire cleaning-port upgrade kit because the dealer wanted $1500 to clean it. Shortly after that, the transmission took a dump because of the overboosting. They ended up replacing the turbo at that point along with the Aisin transmission. Shortly after that it started stuttering and nearly stalling around town. No codes. Turned out to be a bad "gas pedal" (the throttle position switch is part of the pedal assembly).
The truck has been a shop queen, but since it has a 150,000 miles extended powertain warranty, it will be kept until then (has 90,000 now) then it will be replaced with a V10.
44,071 PostsLatest Activity: Sep 17, 2026
