davestarExplorerJul 02, 2013Leak detection in holding tankHi, I just recently took my travel trailer (Kit Companion) on a camping trip and I found my fresh water holding tank has a leak. I looked at the tank which is right below my main bed and I can see w...Show More
opnspacesNavigator IIIJul 02, 2013Probably coming from a loose hose clamp. If you have easy access you might drain it and remove to to see what's up.
Related ContentLeak down test on the LP gas system, leak detected.soap spray leak detectionHolding tank valve leaksLippert faucet leaks, replaced with MoenGray Holding Tank leak
