Huntindog wrote:
cavie wrote:
jfkmk wrote:
Wow, only three posts to get this off topic! Yes, there is a good chance the brakes have been contaminated eith grease. No matter how you try, youll never get all the grease off the brakes. Definitely have them replaced.
Yep. Lots of folks have a problem with reading comprehension. They read things that are just not there. The post was about question brakes shoes. Not Wheel bearings.
Not off topic, and no problem with reading comprehension.
The grease on the brakes comes from the wheel bearings.
On axles with EZ lube hubs, this is a common occurance.
Hence my question. If the OP has EZlube hubs, and uses this feature, then that is most likely the reason he is now probably facing a big bill.
True, grease seals can just fail... But it happens a lot more often when using the EZlube feature.
Agreed, I was going to post nearly exactly what you just said. If anyone had used the EZ Lube feature that can easily push grease past the seal, so it helps in the future.
