On my new trailer I have a leaking fitting. I have contacted the salesman, but wanted to see if any one had any fixes here. It appears the leak is on the fitting between the plastic tubing and male co...
Cut the clamp. Make sure plastic is not cracked. Retighten with Teflon tape on threads. Install new SS hose clamp. I'd do both. Doesn't look like much thread holding fitting. If new dealer should fix it, but that might be more trouble than the 30 minutes it would take you to do it.
