do not use silicone or latex caulk of any kind on a rubber roof. Best thing to use is dicor self leveling sealant found at any rv store, and followed by eternabond seam tape across the front and rear seams. Dicor also makes a "non-sag" sealant that can be used on all other places other than roof, and you should use it around your clearance lights. i highly recommend you remove the screws of each light and dip them in sealant and reinstall them, or replace them if rusted. One of the most common unthought of causes of water damage due to water wicking in through an unsealed screw. Some folks recommend Proflex sealant, but I don't like it because it's too hard to work with and comes out of the tube too tacky to make a nice looking smooth seal using your finger.
