JimK-NY wrote:
egarant, I have also read about leaking outdoor speakers. Fortunately I don't have any and don't want any, ever.
path1, I don't know how to check the A/C gasket. Mine is not visible as far as I know. Can you provide more details.
As far as testing the water system, I have no issues or complexity to doing a test. I turn on the pump, then turn it off. I turn the pump back on hours or even days later. The pump will not run unless the system pressure has dropped due to a leak. You do need to start the test without any hot water. If you start with hot water and the temperature drops, the pump will need to go on to compensate.
good posts on here and lots of YouTube videos about it.
https://www.rv.net/forum/index.cfm/fuseaction/search/parms/sw%7Ba_slash_c%20gasket%7D%7Ckm%7Bexact%7D%7Ckl%7Bm%7D%7Cfm%7B%7D%7Cpd%7B365%7D%7Cma%7B%7D/sr/1.cfm
