TECMike's avatar
TECMike
Leaky Waterpump Connection
My Flojet waterpump is leaking at the plastic connection junction where the water line comes in. There is a blue plastic
compression clip that holds the line plastic fitting in the pump. What is a fix? Thanks in advance.
  • Ended up buying a new waterpump, as my old pump was eight years old. Same model, as it has served us so well. Thanks for all the help.
  • You can replace the 0 ring on fitting, or replace entire fitting/0 ring, or replace fitting/0 ring, and pump. You need to do as much as needed to stop the leak.
    Jerry
  • TECMike wrote:
    My Flojet waterpump is leaking at the plastic connection junction where the water line comes in. There is a blue plastic compression clip that holds the line plastic fitting in the pump. What is a fix?
    Replace it. ;)
