dieseltruckdriv
Oct 05, 2020Explorer II
Slymer wrote:
I am not sure what the point of putting pink into a drained fresh tank would be, at any time let alone for a few years. In any case to winterize I blow out the lines, then flow the pink through, then blow out again. Makes is so much easier to get the pink taste/smell out of the lines in the spring because it hasn't been eating into the lines all winter.
I do mostly the same, I just drain the water, I don't blow it out. Then I run pink through it, then drain that and use the freshly drained stuff in the toilet and sink drains.
I would never put anything in the fresh tank, other than fresh water. Remember, ice cube trays don't break, and if your fresh tank is drained, what little is left won't matter.
