Terryallan
Oct 06, 2020Explorer II
Slymer wrote:
I am not sure what the point of putting pink into a drained fresh tank would be, at any time let alone for a few years. In any case to winterize I blow out the lines, then flow the pink through, then blow out again. Makes is so much easier to get the pink taste/smell out of the lines in the spring because it hasn't been eating into the lines all winter.
First. If you blow it out. No need for pink. second. When I bought my camper they ran water thru the pump. I needed to get that out, Blowing won't blow out the pump. So I needed to get pink to run thru the pump. As I can't get to the back of my pump to hook a hose to pump directly out of a jug. I had to put enough into the fresh tank for it to pick up. And since I don't use my fresh tank. I left it in there. now I just blow it out because there is no water in the pump ..
Hope that explains it all to you.
