valhalla360
May 23, 2022Navigator
Humidity is probably not a big concern in Vegas, so high 80's/low 90's is going to be fine. If anything, you might want to run a humidifier so it does
As others mentioned some oil in the toilet and P-traps so sewer gas can't come back in if they dry out.
Turn off all the breakers except to the air/con & sump pump (assuming you have one).
Turn off the main water valve/pump.
Clean out the fridge, remove food and make sure to clean up any food related spills...otherwise you are likely to draw critters.
