opnspaces
May 26, 2022Navigator III
ceasare wrote:
Thanks for all the info. The only thing I don't know is if I can shut off the water. Have to find out where the drip irrigation system is hooked up. Can't shut that off.
I would shut off the water now and open a faucet in the sink to drain the pressure out of the pipe. Then turn off the faucet and go turn on the drip irrigation. It the drip is still going strong after a few minutes it's probably not controlled by that valve.
But I'll bet that your drip is in fact downstream (after) the valve and therefore will be a problem that you need to come up with a plan for.
