jonlin
Jul 26, 2018Explorer
LED Lights
We have a 2008 990 Artic Fox. We would like to change out the overhead lights with LED lights in the camper. Has anyone done this and if so, what LEDs do you recommend and where is the best place to ...
towpro wrote:
my only advice is to look for LED's that are rated at 12V-24V dc.
Some times your built in charger can push 14.8V, and if you have temp corrected solar you can push up into the 15V range. LED's marked for 12V use will overheat when you start pushing them towards 13V
