6pac's avatar
6pac
LED SIGNAL LITES
Has anyone had to replace the rear signal lights on the Lance?
  • If you apply pressure to one side of that grommet mounted light it will push in. Then you can give it a twist and pull it out. If the grommet has turned hard it may be best to replace them. The lights and grommets should not be expensive. They are commonly found in the trucking industry everywhere. The key is to look at how the wires plug into the back. Get the same type of termination and you will be ok. You won't break the light as they are built very tough. If needed you can push the grommet in along with the light and separate them once they are apart from the vehicle. Hope this helps.
    Dan
  • 6pac wrote:
    Ours is mounted in a rubber ring in the bumper!
    Ours too.
    Heat the rubber rings in some very hot water. Then they are easy to push them back into place with the new LED light.
  • Ours is mounted in a rubber ring in the bumper!
  • 6pac wrote:
    Did you have any trouble removing an replacing the LED lite ?
    You might have trouble if you cant use a screw driver/drill ;)
    Theirs nothing to it.
  • Did you have any trouble removing an replacing the LED lite ?
  • yup ... went to a truck stop , bought them & replaced the one in the parking lot . replaced the other when i stopped for the night :)
