Perrysburg_Dodg
May 05, 2013Explorer
The issue is not that the LED's are not as bright as incandescent. The issue is the reflectors as set up for incandescent lamps. Incandescent bulbs give off light in all directions allowing the reflectors to spreed the light across the whole tail light area.
The LED bulb does not give off light in the same way so the light does not get to all the reflectors and looks like they are not as bright.
So yes if you want LED's you need to buy the tail lamps designed for LED's. Here are some
Don
Don
