AnEv942
Aug 14, 2016Nomad
Huh-found a pic of wiring
Leads direct to boards -bizarre, more so the way its wired. Short of finding boards with dimmer leds, a mini rocker switch to control both cards, Id be snipping a wire in the interim. Even then I'm sure one of the boards be too bright for us.
For experimenting I found couple on amazon-
cheap enough- I have 2 older fixtures with bulb cards w/ failed bulbs (not smd) going to try.
EDIT: ordered & recieved. Way too bright for interior use-nor are they regualted-. removed link
Some soldering involved-just to change a bulb...
