BarneyS
Sep 23, 2013Explorer III
GordonThree wrote:
Snip...
The limiting factor for your GC (and my Ram) is hitch ball weight. I'm limited to 500 lbs (I was surprised it was so low), despite 8800 lbs tow rating. If you get much over 25-26 ft you'll go over 500 lbs on the ball. My KZ 200 is 400 lbs on the ball fully loaded.
Those limits are for weight carrying on the ball. Any tongue weights higher would require the use of a weight distributing hitch and those limits are most likely in the range of 1,000 to 1,200lbs. Those limits should be spelled out on a sticker or tag on the vehicles receiver.
Barney
44,027 PostsLatest Activity: Mar 12, 2025
