martipr
May 15, 2013Explorer
If you have a slinky with hose clamps on the fittings, occasionally check for tightness before dumping. Really messy(and stinky)when the hose blows off the fitting.
When using a blue tote be sure the tote dump valve is closed before you open the TT dump valve. It's unbelievable how much can go straight thru and onto the ground before you can get the valve closed.
I now do as mentioned earlier, dump a little grey water to check everything before dumping the black.
44,070 PostsLatest Activity: Sep 18, 2026
