SkiddyMiller
Mar 22, 2019Explorer
First post here.
Had no real surprises with my 2150RB, it is what it is. GDRV had some construction issues I liked, including solid slide room walls and the use of Furrion range/oven.
Areas that need some attention include the skirts, the edges are leathal, all the edges must be pool noodle wrapped when the slide is extended or if fitting wheel/tire UV covers.
Some of the design points leave me shaking my head. The battens are every four feet to cover the ceiling panels, why did they stick a vent so the vent frame overlaps the batten by an inch or so? The vent in the bath and shower skylight have the same issue only worse.
Under the cabinets and inside the bath vanity, there are “dust panels” that look like someone duct taped then stapled scrap pieces in place.
We have a couple of cold spots on outside walls near the night stands that I’m sure have no insulation at all. Have yet to check that out.
I had a screw driven into the over door valance that missed the support structure by an inch. The valance was about to shake itself loose from the two screws on the ends holding it in place. Luckily there were some extra screws in the water pump cabinet under the sink that allowed me to just drive a screw where it belonged and leave the factory screw in place doing nothing. I had to re hang the bathroom window valance, the support bracket screws had missed the wall backer/framing studs.
Friends have a Forest River Surveyor and a Rockwood, they have similar if not worse issues on build quality. The brand new Rockwood had no hot water on its second night of use. The water heater looked like it had been under water, either the dealer changed it out or it came from the factory in that condition. The numbers did match for warranty registration. The surveyor has had electrical and doors that will not stay attached issues.
I tell SWMBO that it is like they put lipstick on a pig, to hide the real animal underneath.
