gmckenzie
Nov 25, 2015Explorer
Used to do this with my diesel truck. Don't run it for a "few minutes" periodically. Worst thing you can do.
Fresh oil change.
Fill the tires to their max rating.
Fill the fuel tank to prevent condensation (I also used a stabilizer).
Charge and disconnect the batteries. Or use a good battery tender.
Cover as you see fit (I just put the window shade up).
Come spring, check the tire pressure, check fluids, make sure the batteries are charged and then plan to go for a good drive. You want to get the motor heat soaked to remove any moisture buildup from over the winter.
Fresh oil change.
