RCMAN46
Jul 03, 2017Explorer
I use these.
They come with several different scales. With a little testing you will find a scale that is very close.
I like the scale as when I need to add leveling blocks the scale indicates how many inches of leveling block is needed. I have found when it indicates 2 inches that is exactly how much leveling block is required.
Also with my 5th wheel when I have raised the 5th wheel to the height to disconnect I note the reading on the level. Then when it is time to reconnect I raise the trailer to that point and then the trailer is at the correct height to reconnect.
