Hi just read where it is advised to put levelling blocks under both wheels. when levelling a dually. Does everyone use this practice ,if so what type of blocks do you use Thanks
I put blocks under both tires. I use scrap pieces of pressure treated 2 x 10 or 2 x 12 most of the time. I also carry come pieces of 3/4" "advantec" flooring (think heavy duty plywood) to use if I need too. I have some of the yellow plastic blocks that lock together like big Legos; I forget the brand. They work fine too you just have to put a stack under each tire.
