USMCRet93 wrote:
powderman426 wrote:
Folks who use them say no bounce. There its a video out there on how to make them and it appears easy but getting the heavy duty hose is the problem. I would love to make a set if I could get the material.
I found this source of discharge hose...
Lay flat discharge hose.
...not completely sure if this is what is needed, but the specs seem right. The 8" diameter hose is rated for up to 115 PSI.
USMCRet
That appears to be the right stuff, the problem is there is a 50 ft minimum. There was a place that had it in short sections, but when I checked they were out of it.if only I could get a four ft section I would give it a shot.
