Does anyone use those yellow leveling blocks on their dual wheeled travel trailers or is just buying a 2 x 10 and cutting it up work just as well/ Drawbacks? Thanks in advance.
My concern about the yellow blocks is that they may not support the entire footprint of the tire. When that happens the load is taken by only part of the tire possibly overloading the tire. Just overnighting? should be no problem. However, if that condition exists every time out it could be a problem. We use 2 inch thick boards several inches wider than the tire. That additional width also make is easier to drive onto it.
