rbpru's avatar
rbpru
Explorer II
Jul 05, 2018
Leveling chocks
I watches a guy level his TT with leveling chocks. It was rather slick.
On line there are Anderson and Camco models and I was wondering which was the preferred model and why.
I have a 25ft TT so both will handle the weight but I would be interest it which has the largest foot print.
Any suggestions
    Any suggestions
    Neither has an especially large footprint and will sink into a soft ground surface if you don't also use something solid underneath. Either will also easily slip out of position if sitting on a slick surface such as tarmac though Andersen does offer a slip pad to help avoid this. Although rated for the heaviest of rigs there have been some Andersen owners reporting breakage anyway. I personally also wouldn't be comfortable using the Andersen on any site that slopes significantly fore or aft. JMO but after trying just about every method out there I still think parking both low side tires on wood or plastic leveling blocks is the best solution overall.
