Webber229's avatar
Webber229
Leveling Issues
During the process of setting up my TT for my WD hitch, while leveling front to back, I noticed that the passengers side of my TT un-coupled was 24 1/2" on the front pass corner from the frame to the ground and 23 1/2" on the rear pass corner from the frame to the ground. My drivers side however for a perfect 24" across the TT from the frame to the ground. The ground that I was doing this on was level (concrete driveway). My TT is brand new and I have yet to taken it on a trip. I also noticed that my rear bumper which is the 4x4" tube bumper is bent, higher on the drivers side, lower on passenger.
I guess the point of me posting since I'm new to the camper world is are all of these things normal for a new TT? I understand that these things are built on a assembly line so their not going to be perfect but I'm just curious.
I have a 2022 Jayco WhiteHawk 27RK.
Thanks.
  • Thanks for the input, all of my tanks are empty as well and yeah it could be a loading issue, I didn’t think about that. And yes the concrete was flat but maybe it wasn’t perfectly level. Either way I think I should be getting the same measurements on all 4 corners of the frame if it was perfectly level. Also I got under my TT and didn’t notice any visible cracks in any welds and all of my leaf springs and suspension as a whole looks good as well. I will take a more detailed look at it again this evening!
  • schlep1967 wrote:
    Most "level" concrete driveways have some slope in them so water doesn't just lay on them. Borrow a 6 foot level from somebody and check the driveway before you fret too much.
    The driveway isn't level per se, but it's flat, meaning that if he got the same F/R frame to ground measurement on the left side it should be the same on the right too if the TT frame is flat.
  • Most "level" concrete driveways have some slope in them so water doesn't just lay on them. Borrow a 6 foot level from somebody and check the driveway before you fret too much.
  • First thing that comes to mind is loading, is there anything heavy in the RR corner? Sounds like the RR corner has a 1/2" drop that is producing a corresponding rise in the RF corner. Maybe water tank is located there, at 8 lbs/ gal, a 50-gal fresh water tank then weighs 400 lbs.
    I would also have a look at the right side suspension, spring hangers, equalizer, etc to be sure everything is bolted together right.
    a 1/2" out-of-level by itself is not a huge deal as long as it's not a symptom of something more serious.
  • Welcome to the forums. Moving your question to Travel Trailers.
