sylvan001 wrote:
powderman426 wrote:
I would think it would be much easier and safer to use the Yukon and move it back a couple of feet then put down boards and pull it onto them to raise the low side. You don't need anything but a ball hitch to do it that way. If you use jacks, put them under the spring perches and not on the axle.
Ive tried this without the torsion bars and the camper just weighs to much. It sank the rear end of my Yukon...
No one is suggesting you take it for a spin around town... Just hook up and back-up/pull forward onto blocks to level it.
There's no reason NOT to do it... Heck you could do it with any vehicle you own if it had a hitch.
