JimK-NY
Dec 24, 2022Explorer II
BeMurda wrote:
It's funny you all say that you n need to support the base with something under it when the 2010 Lance instruction manual specifically says not to do that?
Read the manual again. It says not to use "tall" supports to store the camper in the "raised" position. The camper should be lowered close to the ground. In theory it is not necessary to use any supports since the jacks should carry the load. I still think it is a good idea to further support the camper. Then there is no issue if a jack fails or Spring rolls around and you find it necessary to replace or work on jack that is no longer working. Maybe I am just extra cautious because I have had jacks fail.
