WarrenS65
Dec 26, 2022Explorer II
I did the same thing with my old camper when I stored it on my sloped driveway. I would lift the camper, pull the truck forward so the front of the camper was over the back end of the pickup bed. I would then lower it enough to take the weight off the front jacks and let them straighten out. I'd then lift it again and drive the truck away. I stored it on a wedge shaped platform so the whole thing was level and supported.
The wood ramps were heavy and a pain to deal with.
I'm storing my Host on ground that's fairly level.
gregchambers wrote:
Unfortunately I don’t have pictures and I no longer need to unload on a slopped driveway but I once did. I found that lifting the camper off the slopped truck bed was challenging, especially when reloading and it placed a lot of stress on the jacks. I would back part way, get out and slide ramps under my front tires and then using 4x4 low range back up the ramps. I made a set of 10” tall wheel ramps from pressure treated lumber that allowed me to back up the driveway and be level. I made four blocks from the same lumber that compensated for the slope so my jack bottoms were level and could not “walk” down my driveway. Using the side of my driveway as a guide and placing small paint marks to show where the ramps should be placed the loading and unloading process was relatively easy.
PS, I’ve had the same 30 orange Lego blocks i use for leveling the truck and placing under the jacks for over eight years with no breakage. Lumber is fine but heavy!
