msiminoff's avatar
msiminoff
Explorer II
Dec 25, 2015
Life with a compressor fridge...
A while back I posted about installing a compressor fridge in my TC. Well, here's an overview of my experience after ~3 months of continuous use;
In most regards the Vitrifrigo has proven to be superior to the Dometic absorption unit it replaced. It sips on electricity, it maintains consistent temperature in both the fridge and freezer compartments, it's has loads of storage space, it cools quickly, it doesn't consume any propane, and I never ever have to think about leveling when parking (of course I still do level when parking overnight).
However I have found a few downsides as well;
- Frost builds up evaporator's cold-plate fairly quickly in humid weather, especially in the fridge (I have kids and they open and close the door a lot!). This means that I need to manually defrost about every 10-14 days. I picked up a 1000W travel hair-dryer and I can do a complete defrost in less than 15 minutes, but it's a chore that I'd rather not have to do. I'm not sure if the same thing would have happened to the Dometic or not. I'll add that this wasn't an issue in the west where the air is much drier, and it only became apparent once we hit the gulf coast.
- As it happens, I'm now in Florida... where it's hot and humid (85ºF, 75% RH), AND it's Winter Solstice & partly cloudy. In these conditions, my 320W of solar doesn't quite keep up with the TC's electrical needs. So, for the very first time since we hit the road in October, I ran the generator for a couple hours to top-up the batteries. This was after two full days of boondocking in Cape Canaveral.
- The Vitrigo fridge has a plastic drip tray between the fridge and freezer compartments. When I spoke with the company's service rep' he described the tray as "optional". In practice what I have found is that in order to maintain the desired temps (~35ºF fridge / ~5ºF freezer), I need to remove the tray in warm weather and re-insert it in cool weather. Once I return home I'll modify the drip tray to include a sliding vent so that airflow between the compartments can be more easily adjusted.
- The door handle/latches provided by Vitrifrigo are a terrible design. Unless you have super dexterity and hand strength (my kids don't), it requires both hands to open the door. To solve this I installed regular cabinet handles (from Home Depot) on both doors... and on the fridge I removed the catch altogether. Now while driving use a small bungee to hold the door shut.
All in all I am VERY happy with having a compressor fridge and I can't imaging ever going back. However, as with most things in life, there are pro's and there are con's.
Cheers,
-Mark
  • With 1100 watts of solar, we are able to keep up with the compressor fridge (NovaKool 9.1cuft) in the Pacific NW winter IF we are parked in the open. If we are in the woods or any shade the generator has to be used. Part of this is probably furnace use also.
    I still love the compressor fridge...never needing to worry about propane, pilot light, fires, being level.
  • Nice report, thanks.
    I guess the key is the effectiveness of the solar. Up here in the Pacific Northwest I find my 150 W solar panel basically does nothing this time of year what with the clouds and rain, low angle of the sun, and trees.
