time2roll
Apr 14, 2016Nomad
Wardster wrote:HMS Beagle wrote:
The solar will do a good job of that if you have a controller with AGM setting.
The standard 95W solar package included with my Northern-Lite came with a EWC-30 Solar Regulator that has an option for a sealed battery. I switched it over to that setting after I finished the install last night.
No. Use the flooded setting. The sealed is for a GEL battery and maxes at 14.1 volts. This is below spec on the Lifeline and will chronically undercharge the battery. Go flooded at 14.5 volts.
EWC-30 Manual
Lifeline manual - charging p19
An adjustable controller with temperature compensation is best.
Possibly use the sealed setting if the temps are 95+.
44,068 PostsLatest Activity: Jun 10, 2026
