landyacht318
Apr 15, 2016Explorer
HMS Beagle wrote:
I think maybe the finicky nature of AGMs is being overstated. They will benefit - a little - from a heavy charge occasionally.
The manufacturer flatly states more initial charge current is better.
Without the ocasional high amp recharge, the time it takes for amps to taper to 0.5% of capacity takes much longer, especially, and more so when accumulating many deep cycles back to back.
While I have a thin plate pure lead Northstar AGM, not a lifeline, I can easily notice when too many low and slow solar only recharges has tanked performance,( voltage drops much lower for AH removed under a given load) and a high amp recharge to a true 100%, is the resetting cure. I deep cycle nearly daily and have a battery monitor at my right hand and this behavior is overwhelmingly obvious. The high amp recharge is Key.
100% recharges are of course important even at a slower rate to achieve them, but when the cycles are deep on these high$$ AGM's, so is the initial charge current as it needs to get that electrolyte a migrating through the glass matting.
Disregard the necessity of an occasional high amp recharge at the cost of the longevity of your expensive AGM battery.
Read the lifeline manual regarding charging parameters, more than once.
And lifeline allows and recommends EQ charges, they just call them 'conditioning' charges since 'Equalization' freaks out the masses when typed near the letters 'AGM'.
Scroll to page 19, read and reread:
http://lifelineb.wpengine.com/wp-content/uploads/2015/12/manual.pdf
You have a 650$ battery bank, do not disregard the manufacturer recommendations as to proper recharging.
Low and slow solar only recharges, on back to back deep cycles, even to 100%, will have these batteries fail prematurely.
The less deep the cycle, the less important the high amp recharge becomes. So claims of longevity without this data point are not much value.
44,068 PostsLatest Activity: Jun 10, 2026
