“PF only matters for speed charging from a smallish generator”
BINGO, and any claims as to the actual numbers must take into account current and voltage (as user adjusted on the powermac device), thus lacking any additional information, an objective comparison cannot be made…Either way, the difference (if any - who can say?) as applied to this particular application is how Statisticians can make Astrologers look good (e.g. mostly marketing)…On the other hand, where Pf is paramount is with a highly inductive load like a motor, where voltage typically lags behind current (numerically decreasing the purported Pf)…
Bottom line, If charging via any generator, it pays to match the size of the various components - fir example, this would include microwave oven wattage..
Also this single point issue overlooks entirely the efficiency gained (while charging LFP…) when comparing to FWC’s higher internal resistance and heat producing absorption stage, meaning less actual generator run time and fuel consumption…
3 tons
