K_Charles
Aug 28, 2014Explorer
When you go over a bump the trailer gets lifted by the axle, at the spring if it has springs. The axle may not be strong enough to lift from the middle but the frame is not strong enough to lift from the end. Look at where the spring is attached and use common sense.
44,068 PostsLatest Activity: Jun 17, 2026
