midnightsadie wrote:
what soap are you usng? buy a bottle of gas leak soap. me I,d pull the unit, in a nice quite area no wind hook a air bottle up about 5# should do and start testing. p.s 5# is more than enough.
I will do that depending on my current test. I disconnected the supply line at the range and capped it off. I turned the gas back on and am letting it sit. I want to be sure no supply line or the furnace is leaking. Thanks for the suggestion.
Edit: meant to say that I added Dawn dishwashing detergent to water.
