- BruceMcExplorer IIITheir seals leave a lot to be desired, but at least the newer styles are using a foam seal instead of butyl tape & caulking...
The problem is the assembly. I got to looking at one of my rear clearance lamps, and discovered:
(look closely at the bottom edge)
(keep looking....)
And this is how it wasn't sealed:
And I'd been spraying water up that direction for 2 1/2 years... fortunately the wiring feeds into a horizontal aluminum square-wall framing member. Who knows how much water migrated in, but so far I've never seen any damage as a result. - chuckbearExplorerStop using caulk. I sealed all of mine with a good quality butyl take and trimmed off the excess. Can't see it and no leaks in over 2 years. Chuck
- T18skyguyExplorer
SidecarFlip wrote:
Easiest solution to leaking clearance lights I know of is replace them all with sealed LED lights.
This is a great idea. With the bulb type lights, their so close to the plastic, that the heat breaks down the plastic and it cracks. I bought new aftermarket LED cab lights that are much higher quality. - OasisbobExplorerWhy O why do the lite mfg,s not include a rubber seal? Too cheap I guess. We all know this is a leak point.
- ChrisatthebeachExplorerI have always removed them, put plumber's putty on the back and replaced, tighten down and clear off the excess, same as setting a sink strainer.
Never had a leak afterward.
If the kitchen sink in a home can go decades without the putty failing it stands to reason works as well on a clearance light. The kitchen gets multiple daily cycles of hot soapy water through it and holds up quite well. - ItsyRVExplorer
As mentioned, clearance lights can have water leaks from two sources, external and internal. Replacing them with sealed LEDs only solves the internal leaks. The sealed LED still has to be mounted and wired to the RV and it's through those penetration points, water can enter the RV through a failed seal. - Harvey51ExplorerGreat topic, thanks to all. I started to replace my clearance lights with LED ones last summer after one got cracked but only did two of them. The tips on caulking are very much appreciated.
- pnicholsExplorer II
You still have to somehow seal the sealed light against the maybe slightly flexible non-metal surface with a hole in it that is behind each light so as to never leak in the worst case scenario of driving into highway speed wind in maybe pouring wind-blown rain.
My clearance lights no longer work - but are still there - because I years ago covered each light's hole in their fiberglass mounting surface with a round piece of Eternabond. - SidecarFlipExplorer IIIEasiest solution to leaking clearance lights I know of is replace them all with sealed LED lights.
- navegatorExplorerMany class C units have phanthom leaks that the owners go nuts looking for and it turns out to be either loose clearence units or bad caulking or cracked lenses or improperly installed new lenses, I had one instance of a leak and remembered that we had a bird strike the day before, climbed to check and did not notice anything wrong until I started phisically trying to wiggle the units and found the center one cracked and that allowed water to get inside the unit and throug the cable hole, used awning tape as a stop gap until I replaced all the marquer lights with new ones a few days latter, so do check those lights they also deteriorate with the sunlight and time.
navegator
