ItsyRV
Dec 13, 2018Explorer
SidecarFlip wrote:
Easiest solution to leaking clearance lights I know of is replace them all with sealed LED lights.
As mentioned, clearance lights can have water leaks from two sources, external and internal. Replacing them with sealed LEDs only solves the internal leaks. The sealed LED still has to be mounted and wired to the RV and it's through those penetration points, water can enter the RV through a failed seal.
