drsteve wrote:
More than likely, it will pull OK without WD.
aftermath wrote:
My big concern is sway and a simple weight distribution hitch does not address that.
Not necessarily true at all - a properly sized and adjusted weight distribution system alone can easily allow towing a trailer without any incidence of sway at all. I do exactly this with my own Coachmen, using a simple Reese trunnion bar WD, no additional sway control. The key is a properly loaded trailer, running a proper amount of gross tongue weight to gross weight ratio, all connected to an adequately rated TV with a properly adjusted WD system that transfers a correct amount of weight to the TV's front steer axle. Do that and it
is entirely possible to tow without any additional sway control device.
