ESDA's avatar
ESDA
Trailer lights
So just got a new trailer and just noticed that when it's plugged into the truck the tail lights and the rear most marker lights are not working, the ones near the bottom and top of the trailer. The break lights and turn signals all seem to work. My last trailer did not have any problems, so pretty sure it's not the truck. The plug looks nice and clean. Anyone have any thoughts?
  • Bobbo's avatar
    Bobbo
    Explorer III
    Run a temporary ground to the light fixture. If the light works, it is the ground. If it still does not work, you have a break in the hot wire.
    If this test shows it is not the ground, start at the last working marker light. Check behind it to see if the hot wire continues on and the connection is good. Go to the first non-functioning marker light and do the same. The problem is between those two
  • take none working lights apart clean things up the ground is most likely the problem.
  • My guess is a bad ground also. A clue is if the lights that do work are brighter than normal.
  • Check for power coming to the lights first but probably a poor ground will be the issue.
  • If some of its running lights work and other don't, it's the trailer.
    If none work then it could be the truck. Need to get out your multi meter to know for sure!
