rfporzio's avatar
rfporzio
Light Trailer Towing
Hi All, I will be taking delivery on my new Jayco 145RB with my 2012 Tacoma. Does anyone tow a light weight trailer without weight distribution and sway control. I do have air bags. tongue weight is 250lbs. with 3000 full load weight.
My plan is to test tow then add if needed.
    With a factory dry weight of 2410 lbs and GVWR of 2995 lbs for a 2018 Jayco JayFlight 145RB it's hard to believe you won't be using all of this trailer's CCC, meaning your biggest challenge will be ensuring it's GVW loaded & ready to camp doesn't exceed it's GVWR. At an average 13% that means it's gross tongue weight should average ~ 390 lbs. Your Tacoma may be rated to handle that much but with some additional cargo weight also likely in the back of the truck I personally would use weight distribution such as the 6,000 / 600 lb Equal-i-zer. Air bags can make the truck look pretty but don't do a thing to transfer weight from the rear of the vehicle to it's front steer axle - a properly sized and adjusted WD system will.
  • Many people pull small lighter trailers without using a WDH. You are right to give it a try, see how it works with your truck. Each truck/trailer can have varying results. If you actually have just 250 lbs tongue wt, with a 3K loaded trailer wt, that is not enough. A 10 percent tongue wt should be minimum, and 12-13 percent would be better, to contol any sway issues.
    Jerry
  • Ivylog's avatar
    Ivylog
    Explorer III
    You should know by now that the WD and sway police will say you must have both, even if it was a F250...OK, maybe not with a F350.:S
    Try it as I doubt you need WD and way is caused by not enough tongue weight.
