Dakota98 wrote:
Quote from MitchF150
"What you have to determine for YOURSELF is what do you feel the most comfortable with in terms of the "tow ratings", "payload", "hitch weight", etc in terms of exceeding or NOT exceeding any one or all of them??
You've got some miles under your belt with your current combo... So, how did it do with your butts in the seat?? Did the driver have white knuckles the whole way? Did the driver say it was okay? Bottom line, would the driver want to tow that combo again?
Depending on those answers and how you truly feel about the actual weight numbers is up to YOU.."
Personally, I agree......BUT
Knowing the exact weight figures & using them throughout the entire equation can be helpful in adjusting the loads to gain that level of towing comfort & performance if you're at or above capacities.
I'm above rated capacities & having that actual weight information has allowed me to make better balanced load adjustments to accommodate the situation. My truck handles like a dream when towing. :B AND I FEEL BETTER ABOUT IT.
I am sorry, that is an extremely sad, selfish way of life.
Just because your "seat of the pants feel" is OK or "acceptable" in YOUR eyes under perfect conditions does not mean it will ALWAYS feel that way under under less than perfect conditions.
The manufacturers have teams of designers and engineers, spend millions of dollars on research and testing then they have to get everything to pass the transportation board and all the regulations.
The manufacturers STAMP THE RATINGS THAT THEY WILL STAND BEHIND as being "safe". Once you go outside those ratings then YOU are taking the burden of being the engineer and there is no way you are going to know exactly how the vehicle is going to perform the task under any conditions.
The "seat of the pants feel" is nothing more than YOU JUSTIFYING being your cheapness of not upgrading to a better platform. YOU are justifying a possible overload which under "good conditions" may tow straight and true.. But under an emergency maneuver like deer running out in front of you while towing at 65 mph and your trailer decides that it no longer wants to listen to the tow vehicle and sends you across the road into oncoming traffic.
Or you round a bend going down a slight incline and have to stab your brakes to avoid slower or stopped traffic and your vehicle loses control due to too much trailer for the vehicle..
Or heck just driving along on a nice sunny day and a gust of wind starts your trailer swaying...
No one wants to think of these things especially when they have justified a bad match..
You are playing not only with your lives but OTHER MOTORISTS, if you kill them and you live then YOU will live with that cheap decision ALL the rest of your life..
If you don't like the idea of buying a better matched vehicle or trailer then perhaps you should sell your RV and go to Hotels.. At least you might not have to live with a bad decision..
Yes, I realize there are lots of TC folks who drive overloaded and yes there are lots of 5vrs and TTs over the ratings, it doesn't make it right.
Yes, even when properly loaded good matches can go wrong but you do have a better chance that it will be a safer rig.
Buying a vehicle better suited for the job should be first and foremost on your list of things to do instead of justifying your current questionable rig.
