1buda
Oct 02, 2013Explorer
Lighting problems
Ok, everything was working fine till now that I'm ready to go in a few weeks. Only the front & drivers side marker lights up. Also the drivers side tail/brake/turn works. It's only the passenger side ...
RoyB wrote:
I picked up these 7-way and 4-way test adapters from AMAZON that connects to the truck side trailer connectors. These adapters has small led lights to show you that everything coming from the truck side is working in good order.![]()
I don't use these adapters alot but it is nice to have in the truck tool box to get you started in the right direction when troubleshooting trailer hookup problem.
I also always squirt some WD-40 into the truck side 7-way connection and move the trailer 7-way plug around pretty good to make sure the connections are being made. This has solved many intermittent type operations of certain lights...
Roy Ken
